07-29-2015 05:53 PM
Hello
I'm using NI-USB 6343 to drive 1 TTL device. This device can also output a TTL signal to indicate whether the gate is opened/closed.
I'm using Digital Bool 1 Line 1 Point. I was able to flip gate open/close in timely manner. But i Like to sync DI and DO properly.
I tried to throw in OnBoard clock but it was not successful.
Is there any way to sync DI and DOI using onbaord/hardware clock?
Any insight will be great!
Thanks!!
Solved! Go to Solution.
07-30-2015 05:05 PM
Synchronizing your DI and DO tasks should be possible with your device. You will need to time them off of a a clock that is usable by both. This information is available in the X Series User Manual
http://www.ni.com/pdf/manuals/370784f.pdf
pg 6-9 and 6-13
You can also find some information and examples of syncing various tasks in the article below.
http://www.ni.com/product-documentation/4322/en/
Best of luck,
Eric
09-24-2015 12:37 AM
thanks!
I got it working!
