07-17-2013 02:09 AM
I want to program EEprom with 9403 module, but i have an error:
Possible reason(s):
Specified route cannot be satisfied, because it requires resources that are currently in use by another route.
Source Device: cDAQ2
Source Terminal: di/SampleClock
Destination Device: cDAQ2
Destination Terminal: Slot1/ConvertPulse
Required Resources in Use by
Task Name: _unnamedTask<D>
Source Terminal: do/SampleClock
Task Name: _unnamedTask<E>
the code:
07-17-2013 09:16 AM
ok,ok there are two order of problems:
the 9403 can't use a timed task with a simple task, and it can't link di trigger with do trigger, uff!
i resolved with this: (the trigger is ai/StartTrigger)
