11-19-2014 10:11 AM
I am trying to run the selftest on the NI6514 DIO module in Visual Studio C# using the.NET interface for the NationalInstruments.DAQmx. When I looked at the prototype it shows:
void selftest();
So there seems to be no way to get the test results back form the self test call. I looked at the equivalent C function call template and it is expecting an integer to be returned.
Is this a bug or am I missing something?
11-20-2014 06:59 PM
Hello KLP
I guess you are refering to the information on this KB
http://ae.natinst.com/public.nsf/webPreview/124D580AE300335E86256FDD006CE798?OpenDocument
There is no reason for this to be interpreted as a bug, it is possible that the functions where just implemented in a different way in each case. But I see your point, it doesn't make too much sense to be able to perform a self test without been able to check the results of it.
Wen R
11-20-2014 08:24 PM
11-21-2014 07:51 AM
Hi Dennis
Sorry about that!
http://digital.ni.com/public.nsf/allkb/124D580AE300335E86256FDD006CE798
Wen R
11-21-2014 09:18 AM
Thanks Wen for taking the time to respond. I had seen that app note but even in that note you can see my issue. In the C code in the note the selftest function returns and INT so the user gets back the results of the test. In the C# code provided you can see there is nothing returned.
I ended up contacting NI and they helped me out. If the selftest fails it actually throws an excepting. So when you check for thrown exceptions using the "DaqException" class you will get a -200020 returned if there is a self test failure. So there is a means to check the test results but using the exception process as a test results return path is unique.....
