05-08-2014 03:19 PM
Does anyone know if there is a niHSDIO Get Session Reference function in the niHSDIO.dll? I see a reference for a LabVIEW vi in the niHSDIO help file but nothing by the same name in the niHSDIO.dll.
Thanks for the help!
(Extra info: I need to get the session reference so I can pass it to TCLK.)
05-09-2014 10:29 AM
hch3,
I am wondering why the session reference is necessary for you? Ususally the associated task handle (ie. ViSession vi parameter found in most C function calls) provides access to any configurations/attributes ext for a given session. Also are you using the C API or .NET?
05-12-2014 06:54 AM
PeanutButterOven,
I'm actually working with the niHSDIO C# wrapper, which doesn't make the ViSession information available outside of the niHSDIO class. However, through modifying the wrapper, I think I was able to get the information out. I don't know what the actual session values look like though. I know if you follow the definition of ViSession back to the header file where it's defined it is actually of type unsigned int or long. When I look at the values for ViSessions I get when I create several Acqusition and/or Generation sessions, they are integers in increasing order i.e. 1, 2, 3, etc. Does this sound right?
That being said, I'm not actually sure if I need this information. I'm trying to synchronize two 6556 cards. I'm going to start a separate thread on that because it is a different conversation.
Thanks 🙂
05-12-2014 09:55 AM
You are correct that about the values of ViSession, they are integers. I also believe that you are correct in saying that you do not need this information to sync two 6556 cards
