04-25-2014 10:51 AM
I currently have 2 different versions of DIO in my system. I have a PXI-6533 with code that operates as advertises with my current code. I built a new system that has the PXIe-6536 and I am trying to use the same code to run a specific test. I am having trouble with the PXIe-6536 working like the PXI-6533 and I am trying not to have 2 different versions of code. I have attached my VI for reference. The problem I am experiencing is related to the trigger, I trigger on a zero and capture the next 11 samples to match a pattern. With the PXI-6533 this works great but not with the PXIe 6536 any help or recommendations would be great. Also please keep in mind that I am using 8.6 LabVIEW..... I know ancient and archiac but its what i use right now.
04-30-2014 08:04 AM
SNissen,
Are you getting any error in particular? or incorrect data?
