12-27-2015 09:53 AM
Hi all
How can i understand whether my sensor is generating signals or not?Cause i cannot receiev any signal via my DAQ
Regards
12-27-2015 11:04 AM
12-27-2015 11:09 AM
Yes it is a ttl signal when i wire it to osscilloscope i see a constant line on 5v.I wired it correctly because i got wiring information from authorized person of sensor.my daq is ni usb 6229 bnc.Shortly according to the sensor output signal should be square wave
12-27-2015 11:59 AM
12-27-2015 01:22 PM
Actually it is not exactly 5V fluctuating a bit but very small.I am providing the sensor and how i wired it., xample of labview i used count digital events pause trig but i have seen no data.
12-27-2015 01:45 PM
12-27-2015 02:01 PM
They sent me this picture. i wired signal cable to pfi4. supply voltage is 12V.resistance is 2.2k because sensor manufacturer said you have wire a pull up resistor as in the picture.
12-27-2015 02:51 PM
12-27-2015 02:58 PM
Then teach me how to look without daq card, i am new in this kind of stuff.You always give instructions.
12-27-2015 03:53 PM
