04-22-2008 01:17 PM
04-23-2008 02:09 PM
jcao,
There currently isn’t a function that will return the available on-board memory during acquisition or generation. You can accomplish this by using the Total Acquisition Memory Size property and keeping track of how many samples you have taken.
A good example to follow would be the Dynamic Acquisition of Large Buffer.vi in the LabVIEW example finder: Help >> Find Examples.
In this example they do a calculation to determine the total number of samples taken thus far. This example might also be a good place to start if you are acquiring a Large Data set. It will acquire the Digital Waveform in pieces and then save it to the hard drive.
Also when acquiring data you can set the data width (size) of the sample according to this knowledge base article. Based on this number you should be able to specify a data width that will allow you to utilize the 8MB/ch on the 6552.
I hope this helps!
05-11-2016 10:28 PM
Hi NI Folks,
I am not able to access the knowledge base article mentioned in this thread. Can someone help?
Thanks in Advance!
Laxman
