07-01-2015 08:57 AM
I am trying to install the proper driver for the USB-6501. I used the iso file from the link below.
http://www.ni.com/download/ni-daqmx-base-3.7/4269/en/
My system said that the install was successful, however when i go to open up one of the applications (such as Driver Wizard or NI I/O Trace) I get an error message. It says "failed to execute child process "usr/local/bin/niiotrace" (no such file or directory)). But I go to that directory and I see it is there. Is there something else that I need to install or did I do something wrong during the install process?
I am currently running redhat 6.6 with kernel 2.6.32-504.el6.x86_64.
07-07-2015 04:53 PM
You can try to download this newer verison:
http://www.ni.com/download/ni-daqmx-base-14.0/5054/en/
You can check the readme file and the description to see that is compatible with your OS and also with your hardware.
