10-06-2013 05:55 AM
thank u WanL for ur reply.
u described abt varying duty cycle without using counter by regenerating pulses in a loop. but in this case i also want to vary frequency of the two digital pulse trains.
waiting for ur response..
10-07-2013 01:02 PM
Your sampling rate is fixed by the sample clock. If you want your output frequency to change, you can vary the number of samples per period of the waveform that you generate on each iteration of the loop.
04-19-2014 03:22 AM
i got this code modified
04-19-2014 03:23 AM
also download this
04-19-2014 03:25 AM
thank u wanLfor ur help.
