Digital I/O
how to generate a continuous ttl signal with a USB 6501
Hello everybody,
I'm a beginner with LabView, so maybe my problem is very easy to fix.
I need to generate a digital output using a USB-6501. This TTL signal will then be used as switch for a device. Basically I need the digital output to be continuously at high TTL level until a user activated start is given. Then the digital output must stay at low TTL level until another user activated stop is given.
Does somebody have any suggestion of how to do this? I haven't managed so far to get anything different from a TTL high level from my usb 6501.
Many thanks.
(6,744 Views)
Accepted by topic author minni
Hi there, take a look at the VI I'm attaching. You can find more information about the device in the manuals and on this forum. I hope this helps
Alejandro C. | National Instruments
(6,728 Views)
the DO of your DAQ is an "open collector", tie a pullup 4.7Kohm to the DO and connect the other end of it to the 5Vdc output of the DAQ. in your vi, supply a lo(F) to it and you will see a lo ttl ouput, supply a hi(T) and it will pull up to the 5Vdc output.
(6,713 Views)
Many thanks. That helped a lot.
(6,702 Views)
The example given is for Labview 9.0 ad above.  Do you have the example for labview 8.5?
(6,651 Views)
There you go! Smiley Wink
(6,639 Views)
Here is how you would have it output continuously a 1 second TTL on a device like a 6508.
Chase
NI Technical Support Engineer
(3,542 Views)
