11-13-2015 12:48 AM
I'm working on a project, i need to interface Yokogawa WT3000E with Labview 2013 using USB Interface, I have downloaded labview driver for yokogawa and USB Driver, I searched through the net and found that WT3000E needs .inf file for interfacing, I created .inf file using NI-Visa, But in Visa Resource name i was not able to find it. Suggest me wth a solution.
11-13-2015 01:11 AM
When i tried to create .inf file, i'm getting an Error in NI_VISA. Wheras in Labview Visa Resource Name i'm getting an Error (Class Conflict).
11-13-2015 01:45 AM - edited 11-13-2015 01:46 AM
The WT3000 cannot be used in the 'normal' way with the USB interface.
Install the driver that is in the attached ZIP.
The broken wire is caused by a incompatible VISA control. Create a new one if this error persists.
Kees
btw. this message should be posted in the Instruments board.
11-13-2015 11:40 PM
Hi, Thanks for the reply.I have Successfully interfaced Yokogawa WT3000E with labview. But, when i run my .VI ,sometimes i'm getting an Error, Instrument reports: 410,"Query INTERRUPTED;" 0,"No error". How to rectify this Error???
11-14-2015 01:21 AM
11-16-2015 02:32 AM
Are you sure you are using the WT correctly ? Check how the the examples are working.
Can you post your VI here ?
Kees
