01-07-2014 05:56 PM
Hello, i have a problem with Labview 2013, on my pc(where i make the Vi from zero) work verry good, but when i put the Vi on laptop with the same version of labview, i get error from scan from string. hardware part are not changed, why i get this error? this is my VI.
01-07-2014 06:12 PM
Put some probes or indicators to see what is being returned from the VISA Read. It could be a simple synchronization error. Try reading more bytes.
01-07-2014 06:41 PM
i try to read more bytes(1000) but with no succes, i put a probre after match exact string, i atach a photo, so error is in block scan from string.
look in the photo i post what i read from visa read.
01-11-2014 10:51 AM
i have a suggestion, if i make the VI an executable file, so on the laptop i will don't need LabVIEW, will work fine or? i will have same error?
01-11-2014 12:59 PM
