Digital I/O
digital square signal
Hi all,
I want to verify if my digital square signal turn on or off. If someone Has a idea, please help me
I created a Mask, in such a way that if my signal leave the Mask. I will have a Message Error. It's work but I should each time modify the values of Culsters of the function 'Limit Specification" If I change the Signal
You Will find in the attached file the block diagram.
Thank you in advance for your answers
Best Regards
(5,203 Views)
Do you want to do this comparison on the fly or post processing?  You are currently doing a post processing.
I'm not understanding exactly what you are looking for.  Are you just looking for when the value changes?
GCentral
(5,198 Views)
My input represents a flashing light's signal, I want verify if its brightness increase or decrease, and if My light respect the duty Cycle that it is 50%
I don't know if I was clear enough
(5,195 Views)
Accepted by topic author k.nadia
How are you measureing brightness?  A digital signal is On or Off.
Duty cycle you can measure simply enough.  There is a VI called Pulse Measurements.vi that will do that for you.
GCentral
(5,193 Views)
Yes, You're right I forgot that I have  a Digital input
Thank you
(5,191 Views)
