10-13-2014 11:25 PM
I'm new to here, hopefully some one could give a hand. Thanks.
I have cDAQ platform (NI9178) with NI9403 & NI9222 modules. I need 6 lines of NI9403 as output for a scanner address (from 0 to 63 continuesly scan). Using one channel of NI9222 to measure the scanner voltage output.
The scanner max speed is 45kHz.
Please Help!!!
Thanks so much!
10-15-2014 10:02 AM
Hi Tscuw,
Would you be able to provide more information? What specifically is your question? If this is a "getting started" question, I recommend utilizing the NI example finder to find base code to start working off of.
10-15-2014 11:46 PM
Hi Kirsten,
I'm going to try to explain as detail as possible.
I have a ZOC33 scanner that measures 64 points of pressure (in voltage form). Address, from 0 to 63 should be sent to the scanner one at a time so that the scanner's multiplexer will switch to the proper pressure point.
I use 6 lines of NI 9403 outputs as address control while one channel of NI 9222 continuously collecting data.
In Create Channel vi, I select "one channel for each line" mode. A 2D array (6x64 size) is made to write them in Write vi (2D Boolean mode). I hope it will let the digital outputs continue cycle in hardware timing mode from 0 to 63. I just can't configure it right.
I kHz of digital scan rate was used.
Thank you very much!
10-16-2014 12:10 AM
