08-20-2015 03:37 AM
Dear NI forum members,
I am using NIDAQmx C API to implement a behavioural driving program. I would like to monitor a digital input port for an event, and every time a trigger exist I would like to generate a discrete digital pulse of some define width (e.g. 0.1 sec). The PCIe card is named NI PCIe 6321 from the X-series. And the connector block is called NI BNC-2110. Here how far I am now:
/* configure read port task */ DAQmxErrChk(DAQmxCreateTask("ReadPort", &readPort)); DAQmxErrChk(DAQmxCreateDIChan(readPort, "Dev1/port0/line0:7", "", DAQmx_Val_ChanPerLine)); DAQmxErrChk(DAQmxCfgChangeDetectionTiming(readPort, "Dev1/port0/line0", "", DAQmx_Val_ContSamps, 1)); DAQmxErrChk(DAQmxRegisterSignalEvent(readPort, DAQmx_Val_ChangeDetectionEvent, 0, ChangeDetectionCallback, state)); /* configure write port task */ DAQmxErrChk(DAQmxCreateTask("WritePort", &writePort)); DAQmxErrChk(DAQmxCreateDOChan(writePort, "Dev1/port1/line0:7", "", DAQmx_Val_ChanForAllLines)); # in the Callback function write to digital line /* change detection callback function */ int32 CVICALLBACK ChangeDetectionCallback(TaskHandle taskHandle, int32 signalID, void *callbackData) { uInt8 data[8] = {0}; int32 numRead; unsigned char lineBits = 0x01;
/* read port at event */ if (taskHandle) { DAQmxErrChk(DAQmxReadDigitalLines(taskHandle, 1, 10.0, DAQmx_Val_GroupByScanNumber, data, 8, &numRead, NULL, NULL)); /* if any bits changed trigger a pulse */ if (numRead) { DAQmxErrChk(DAQmxStartTask(writePort)); DAQmxErrChk(DAQmxWriteDigitalU8(writePort, 1, 1, 10.0, DAQmx_Val_GroupByChannel, &lineBits, NULL, NULL)); /* somewhere here update lineBits to ground (0) level and write after some time */ # pulse width time delay ??? also I do not want to use a delay command inside the callback function # will it keep it blocked if event arrived while it is being delayed lineBits = 0x02; DAQmxErrChk(DAQmxWriteDigitalU8(writePort, 1, 1, 10.0, DAQmx_Val_GroupByChannel, &lineBits, NULL, NULL)); DAQmxErrChk(DAQmxStopTask(writePort)); } } return 0; }
Any help or direction will be helpful! Thank you in advance!
Best,
Georgi
08-21-2015 03:55 AM - last edited on 01-08-2024 02:19 PM by migration-bot
Dear Georgi,
You should configure a retriggerable task (https://www.ni.com/en/support/documentation/supplemental/21/retriggerable-tasks-in-ni-daqmx.html)
With your PCIe-6321 X-Series board and it's Advanced timing and triggering with NI-STC3 timing and synchronization technology, you can do this application while using only one onboard counter.
Best,
Marc Oesterle
Applications Engineer, NI Germany
