Digital I/O
digital input pin transition
I am in need a help fellow Labview users. I am using an external controller board with a digital pin that will used to synchronize thermocouple temperature measurements.
In doing this the following is the logic I am trying to implement.
  1. Detect a low to high pulse transition
  2. Then, start a timer
  3. Detect, high to low pulse transition
  4. Then, stop timer
  5. Then record time delta
I am using a NI-6009 multichannel I/O module
I truly do appreciate help with this!
Lawrob
(5,510 Views)
This sounds like what you really want to use is a counter.  You can setup a Two-Edge Separation counter that will do what you want.
GCentral
(5,497 Views)
Thanks for the response but I do not have a counter and only have the NI-6009 I/O module. Do I need a specific type of counter or equipment to do what you recommended?
(5,480 Views)
Actually, most NI DAQ devices have a counter.  In the case of the US-6009, it just counts negative sloped edges.  If you want to keep with USB, you should go with a USB-6210.  It has 2 counters on it that you can perform the two-edge separation measurement with.
GCentral
(5,476 Views)
