12-27-2012 07:19 AM
we use 2 pcs of usb-6501 at 17 meter lenght by using a 12 meter and a 5 meter Aten USB. Extension cable.
we use VB.net 2008. programming.computer Dell vostro
sometime we have got an error.
device can not be accessed possible caused
device is no longer present in the system.
device is not power.
device is powered but temporarily without power
device is damaged
status code :201003
but we do beleived device is not damage and alway has power.
because we disconnect and reconnect the usb cable and
the system can work fot a while before get the problem again.
Can anyone suggest me how to remove this problem ?
Solved! Go to Solution.
12-28-2012 08:04 AM
In your vi, are you working with DAQ Assistant? If your answer is positive, the problem can be related with the configuration of the channel that you assign in the DAQ Assistant because when you configure for one channel and then you change the USB-6501 to another physical connection on the computer, the internal settings on the DAQ Assistant do not get updated, For that reason I would suggest to you open the DAQ Assistant where you select which physical channels are tied to the acquisition and select the proper channels on your device and close the DAQ Assistant. This is a good first step to solve your problem.
12-28-2012 08:19 AM
We have set device name "dev1" and "dev2" in NIDaqmx.
we have not changed any physical connection.
12-28-2012 09:56 AM
What is the LabVIEW version that you have?
What is the NI-DAQmx version?
12-28-2012 02:38 PM
have you changed the power management options for the USB hub?
That often helps keep USB devices powered up and connected
12-31-2012 10:14 PM
Hi Marand,
We have not use Labview for this application.
Our NI DaqMX version is 9.5.5.
regards,
ArchanB.
01-01-2013 01:56 PM
01-01-2013 09:35 PM
but we tried to use ATen USB. active extension cable.
01-02-2013 12:21 AM
01-02-2013 06:25 AM
We already did and it worked well.
even at 17 meters lenght many times that it also worked well,
but not so stable.
regards,
ArchanB
