Hello AutonomousMode,
have you deleted the elapsed time vi and replaced them stop with a false constant?
- Make a indicator for the iteration of the loops.
- Go in the specification under advanced you find a checkbox enable debuging, set this please.
- Build and deploy the startup.
- In LabVIEW under operate is a option to debug the a exectuable, please select your Rio and look, if the code is running, or what happend.
Does a simple vi without the kukabot vi´s run?
For what platform are the vi´s designed, that the kuka bot controls, is there a DLL inside or not?
You said you can control the bot, if the vi´s run on the host, how does the communication works inside of the vi´s?
best regards
Alexander
