11-24-2014 11:04 AM
Hi, I'm new using DAQ and LabVIEW. I've project to control degree of servo motor. can device NI-DAQ6008 control it? I ever used pwm example but I had some error before the program running it.
example motor servo which I want control.
thank's
11-24-2014 03:08 PM
11-25-2014 12:49 AM
error task on DAQ is not correct with data, data pwm write 100 in second and DAQ only 1 task. I'm confuse what should I do, or any solution for control servo with DAQ 6008 without pwm?
11-25-2014 10:31 AM
Hello NMaolana
This is another thread that actually talks the same issue https://forums.ni.com/t5/Multifunction-DAQ/usb-6008-dc-stepper-servo-motor/td-p/2320144 and in there you can see that you can't do a proper control for a servo due to the jitter given the fact that this device only has software timed outputs. If you would like, read through said thread.
Juan B.
11-27-2014 12:05 AM
thank's all for give me you're experience
