02-19-2017 11:36 AM
Hi,I'm trying to control some servos for my final project and i'm using labview 8.5, cRIO 9002, chassis 9102, and NI 9472 digital output module. I know it's kind of old but it's what i got. The main problem is that i can't find a way to control the servos using the digital output. I've searched everywhere and i still can't find a way. I'll be very grateful if you could help me, thanks.
02-21-2017 08:43 AM - last edited on 01-08-2024 02:18 PM by migration-bot
Hi rolandonunez
I found this document where actually uses the same module than you to send a pulse width modulation to the motor Getting Started with CompactRIO - Performing Basic Control . I’m not sure if LabVIEW 8.5 have this functions but you can use it like a base. Also I recommend you to search on the examples of LabVIEW, you can access to them through the option of help and find examples. In our community you can find a lot of examples I let one here Servo motor (RC) control using LabVIEW
For last if you are new with cRIO a recommend you to check this information, is a guide for cRIO NI LabVIEW for CompactRIO Developer's Guide
Best Regards.
LaNiña || CLAD
