Digital I/O
binder convection oven talking with PC
Hi
After reading some technical binder docs I give up.
I let you some information that hoppe can help you.
Best
cpalka
Message 21 of 28
(2,108 Views)
From other commenters here it sounds like the communication protocol is MODBUS. There's some LabVIEW MODBUS VIs that can be found here: http://www.ni.com/example/29756/en/
There's also some general information on using the MODBUS protocol and getting started on this page: http://www.ni.com/white-paper/52204/en/
R Dahlman
Message 22 of 28
(2,074 Views)
Did anybody have success in talking to an BINDER chamber over Modbus?
I have got the "Binder Interface Technical spec 10-2017" (PDF), but I would like to have an example hot to control and monitor chamber.
Could anybody give an example vi, please?
Thanks and BR
EW
Eugen Wiebe
Bernstein AG
CLAD - Certified LabView Associate Developer
Message 23 of 28
(1,665 Views)
I had some success using this methods (see attached files)
Eugen Wiebe
Bernstein AG
Message 24 of 28
(1,661 Views)
It seems some users on this forum have had success by reaching out to Binder so I would definitely recommend you do that as well. Also, this forum thread is older and if you are looking to see if anyone on the NI forums has any helpful info I would recommend you create a new thread for the best chance at traffic.
Aaron F.
Message 25 of 28
(1,642 Views)
Hi all,
Use this Vi this one worked for me.
Try once using port number 10001 and instrument ip Address.
Follow the user manual for the instrument which has the commands for different functions.
Rakesh
Message 26 of 28
(1,607 Views)
Thanks  EWiebe for your help it helped me.
Thank you very much.
Rakesh
Message 27 of 28
(1,606 Views)
Here my C# class for working with the oven.
Hope it helps
Eugen Wiebe
Bernstein AG
Message 28 of 28
(1,602 Views)
