Hi T2004
Following on from my last post, the device uses the TTL standard but the output impedance will largely depend on the mode in which you are using the device. What sort of system set-up are you using with the NI 9401 and what is your application trying to achieve?
I may have understated the input impedance in my last post as I was basing this estimate on another device.
Were you able to measure the impedance at your end?
Kind Regards
Marshall B
Applications Engineer
National Instruments UK & Ireland
