07-10-2015 01:57 PM
Hi
What are the max practical limits for the sample clock using the Shielded Single-Ended Flying-Lead Cable?
I am playing with the Labview embedded example "Dynamic Generation and Acquisition Source Synchronou.vi" using the Shielded Single-Ended Flying-Lead Cable and the PXIe-6556.
This example write in the channels 0-7 and read in the channels 7-15.
It also export the sample clock and data active event so we have a "Source Synchronous"
I change the original example to set the input impedance to 50ohm and VH and VL voltatages.Write 3.3V - 0V and read 0.5V 0.3V.
The problem is the signal integrity at higher frequencies. Please see the picture attached.
Sample clock 30MHz
50MHz
70MHz
90MHz
Error: PLL could not phase-lock to the external reference clock.
07-16-2015 03:49 PM
Hello engfpe,
According Hardware manual the Maximum Sample Clock rate is 200 MHz.
http://www.ni.com/datasheet/pdf/en/ds-421
Is not clear for me if your error message was received on LabVIEW or on your Agilent Scope, and I don´t know your Agilent Scopes specifications. Neither I don´t know what exactly you are trying to generate, maybe if yo ucan clarify more your application and your issue I can help you more.
07-21-2015 06:52 AM
The error message came from the Labview. The scope is a Agilent MSO9254A Oscilloscope 2.5 GHz.
I am using the example "Dynamic Generation and Acquisition Source Synchronous.vi" to verify which is the max frequency I can send the digital signals in the source synchronous configuration.
There is any circuit I just connect input and outputs directly. In the scope we can see that the "ddc clock out" signal" is degrading when I increase the frequency.
