Reply
Wait instrcution timeout
I'm using PXI6552 with scripting. I use the wait instrcution with scripttrigger (Digital edge).
I would like to know if there is a possibility to configure a timeout for the Wait instruction because in the case the trigger never happen, I don't want to block my script
Thank you
JPV
(1,794 Views)
Re : Wait instrcution timeout
Hi JPV,
Thank for using National Instruments discussion forums.
If you have questions about scripting,please refer to the API Community: LabVIEW Scripting Main Board. I think you will get the best help there.
Audrey_P
National Instruments France
Journées techniques : des fondamentaux aux dernières technologies pour la mesure et le contrôle/comm...
(1,777 Views)
My question is not about LabVIEW scripting but about HSDIO scripting, so I'm not sure The API Community: LabVIEW Scripting Main Board is the right place to post my question.
could you confirm?
Thank you
JPV
(1,769 Views)
Re : Wait instruction timeout
Hi JPV,
You can configure the niHSDIO Wait Until Done VI or C function to give your script a programmatic timeout parameter, which will cause your program to error and exit gracefully in the event that a hardware script trigger is not detected within the timeout period specified by your code.  I hope this helps!
Kyle A.
Staff Product Support Engineer - R&D
(1,749 Views)
Highlighted
This is what I currently plan to do and I wanted to be sure it was the good method
Thank you.
(1,738 Views)
