07-28-2015 10:47 AM
I have an NI9401 in a 9174 chassis. I would like to measure the velocity of a bullet. I have 2 optical sensors, each that put out a 5V pulse when the bullet passes thru the beam. The only input should be distance between sensors and units (ft or m) and the output should be time in seconds and velocity in either feet or meters per second. This should be about as simple as it gets. I've been looking for an example .vi and haven't been able to find one yet.
07-29-2015 02:29 PM
robk,
The reason is because is a very specific application.
I will recomend you to create this application by yourself using two Digital Input Task with a daqmx timing (change detection). Then calculate the elapsed time between the two value changes of the signal using a VI similar or this one
http://digital.ni.com/public.nsf/allkb/6F6B9F4E149C80578625652800784764
to get the velocity is just measuring the distance between the two places in where you placed your sensors and applying V= t/d
07-30-2015 02:08 PM
Thank you for your reply. Can you tell me why this isn't working?
rob
07-31-2015 10:43 AM
Is because of the way you are configuring your task.
Take a look at this example that use a digital edge trigger and a reference digital edge trigger as you
http://digital.ni.com/public.nsf/allkb/BA775B0E445BFA79482571FE0032CCEB
