09-29-2014 07:00 PM
Newbie to labview. Would like to know if one of DIO lines on the NI-8452 can be configured as SPI_DATA (SPI_MOSI). Synchronizing it with the SPI_CLK.
I’m using SPI_CLK as the RCLK for 74hc595. DIO1 as SER data input to 74hc595. DIO2 as RCLK for 74hc595.
Thanks.
kvn
09-30-2014 09:31 AM
Hey kvn,
Unfortunately, the DIO on the 8452 are all software-timed, so there isn't a way to tie their output to a hardware clock like SPI_CLK. They are really intended to be used as basic DIO lines for evaluating external conditions that may need to influence the execution of your application, rather than as hardware-timed input or output.
If you would like to read all of the capabilities for yourself, check out the NI-845x Hardware and Software Manual.
I hope this helps.
Ryan
