NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
hftsai
USB6501 for 2 marching TTL signal?
Hello, i'm a newbie in labview.
It is a program requested by my teacher..
but i am getting fraustrated.
The task should be simple. two marching TTL signals output, the sample rate is only "1Hz"
I was trying to use the digital waveform and to boolean output the digital waveform into the DAQmx..
but there is some channel.data in-coherence..
i don't know how to fix it..
i thought there would be a couple ways to do..
but i was having trouble figuring out how to output TTL signal
I wonder if anyone could lend me a hand.
Much appreciation in advance.
 Paul Tsai
Knight of NI
Dennis_Knutson
Re: USB6501 for 2 marching TTL signal?
[ Edited ]
You don't have anything wired to the data input of the DAQmx Write and if you tried to wire the digital waveform you would probably get an error since the 6501 does not support hardware timed I/O. If you do get an error, it is essential that you provide the error code.
edit - where do you get the idea that your sample rate is 1Hz?
Member
hftsai
sample rate of 1Hz was a request that for each digital pin the signal switch on and off after 1sec.
I'll try some more
thx
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
