NI Home
Cart Cart | Help
You are here:
Reply
RTSLVU
Accepted Solution
USB-8451 I2C slave mode?
I have a device I need to test that uses I2C bus.
The device is a board with a microprocesssor on it that is an I2C master
Can the USB-8451 be an I2C slave?
John_M.
Re: USB-8451 I2C slave mode?
Hi RTSLVU-
Unfortunately, the USB-8451 cannot currently function as a slave on the I2C or SPI bus. Please consider visiting the Product Suggestion Center and submitting this feature as a product request. The more suggestions that are made, the more likely is that this functionality will be implemented in a future version of the hardware.
Best Regards,
John M
Applications Engineer
RTSLVU
Thanks, I submitted a suggestion.
Now I understand why this USB-8451 was sitting on a shelf collecting dust.:smileysad:
We decided to go with this device from MCC because slave mode is required to test our product.
 iPort/AI
miniMe
I'd like to know if there any updates regarding functionality of the NI USB-8541 as a I2C slave ?
Thank you
Daniel-H
Unfortunately, there haven't been any updates for using this device as an I2C slave.
Daniel
gn0778
Any news about this? Is it a hardware related limitation or only a software issue that the USB-8451 cannot be a slave? We also need a slave device to test our battery chargers in our products.
