09-18-2015 08:10 AM
i have a USB-6501.
i would like to write a sequence of "1's" and "0's" to form a byte
so for example i would like the 6501 to write say 1001000 or 11100110 using the digital outputs so "on" "off" "off" etc
thanks
09-18-2015 10:14 AM
@bennyk wrote:
i have a USB-6501.
thanks
What have you tried so far?
09-18-2015 10:19 AM
i have just used the DAQ assistant to manually write "1" and "0" to make the sequence. i literally just recieved the hardware so am very new to it.
i have been trying to find exampls but no luck in finding ones that generate bytes
so what i would like to have is a combo box that contains say 10 numbers. then when you select one of these numbers it will casue the 6501 to create a specific byte say if i select the number 13.1 then it would create a sequence of 1011 0011 for example
09-18-2015 11:27 AM
