03-30-2016 09:10 AM
Figure 4 of the NI USB-6501 OEM User Guide shows a port IO circuit. Rp is populated with a 4.7 kOhm pull up resistor. The documentation states an output can be configured as push-pull. Does that indicate that actual micropin on the USB microcontroller, as shown in Figure 3 block diagram, will be configured as push-pull, basically overriding the pull up / open drain circuit? Is there circuit diagram of what an actual port pad looks like? That is, when push-pull, does the port pad have a dual transistor circuit connected to it?
Reviewing the PCB, I observe a low side transistor on all the pins with the 4.7 kOhm pull up resistor, Rp.
Thank you.
03-31-2016 11:45 AM
Hi Tony,
You have to software configure your digital output port so that it becomes a push-pull output. To do this, there are several ways outlined in this KB:
http://digital.ni.com/public.nsf/allkb/D9B4018C3E540CE4862570F30068C0DB?OpenDocument
This forum post also highlights how you can change the output type in software:
http://forums.ni.com/t5/Multifunction-DAQ/USB-6501-DIO-Push-Pull-Configuration/td-p/1151965
Once you set this, the DAQ device will automatically change its settings in order to operate as a push- pull device. No, there is not an explicit circuit drawing of the proprietary hardware for the port pad. Figure 5 of the manual shows the basic port configuration for the different output types.
04-07-2016 08:05 AM
Hi Roxana. Thank you for the information. When I try the links you provide, they do not work. Maybe I am doing something in error when I try to execute them.
A question regarding your statement below regarding the port pin circuit. Acknowledged you can not show the circuit detail. However, based on Fig 6 of the User's Guide (you state this below), the port is open drain with the pull up resistor. Hence a change in software then reconfigures the port pin to actually have the structure of a push pull transistor circuit? I'm trying to wrap my head around the pull up resistor now in parallel with high side FET (I suspect). As I look at the board I see a low side transistor and the 4.7 kohm resistor. I am thinking about the output of the microcontroller connected to that circuit.
Thank you.
tony
04-08-2016 06:20 PM
Hi Tony,
This link should work. I've added the title so you can at least search it as well
How Do I Configure My NI Device to Be Open-Drain (Open Collector) or Push-Pull (Active Drive)?: http://digital.ni.com/public.nsf/websearch/D9B4018C3E540CE4862570F30068C0DB?OpenDocument
Title of Forum:
I can try and gather more info on what exactly the software does when we're configuring the push-pull configuration.
04-14-2016 02:46 PM
Hi Tony,
It looks like you may have found a documentation issue. We're still trying to pursue this to get to the bottom of it, but I'll let you know once we do!
04-15-2016 02:30 PM
Thank you for the information. The link to the note works. The basis of my original question is to understand correctly this output structure of the USB-6501; hence, apply the part correctly.
04-18-2016 05:12 PM
Hi Tony,
I did get some clarification on this. In Figure 6 of the 6501 User Manual the circuit depicted acts like an open drain and will weakly pull up to 5V. When the Push/Pull configuration is configured, the DAQmx driver basically adds another resistor into the circuit that drives the voltage. Unfortunately that's as much info as I can provide, but I hope that helps!
04-19-2016 07:11 AM
Interesting. Thanks for digging into this. Not how I think of push-pull, but all info is good info. My application I bufffer the USB-6501 digital out as a conservative approach to the design.
tony
