Digital I/O
USB-6501 Z (high impedance)
I am trying to use the IDW library to create a master using the USB-6501. My problem is the Write DAQmx gives an error when it try to use 'Z' setting for high impedance. Are there any work arounds for this?
(4,289 Views)
Accepted by topic author al.hussain
6501 doesn't support Hi-Z state... low-cost vs. high-performance, and you've got a low-cost DIO.
Might be able to set the output to an input, but there's still the internal pullup you'll be fighting with.
(4,282 Views)
Thanks for that information.
(4,274 Views)
