We recently upgraded our C# software from .net 3.5 to 4.0. Since then, on a few computers, we are getting a System.AccessViolationException error. The problem is intermittent and appears on both Windows 7 and Xp. Below is a partial stack trace from the Windows Event Viewer. Has anyone ever seen this? These systems have been working reliably for many years.
I've tried re-installing the NI-DAQ software, upgrading to 9.5.1 and re-installing the .net framework. To get the system functioning again a hardware re-boot is required.
Any suggestions on how to correct this would be greatly appreciated.
System Details:
** OS full name: Microsoft Windows XP Professional sp3
** OS platform: Win32NT
** OS 32 or 64 bit: 32 Bit
** OS version: 5.1.2600.196608
** CLR version: 4.0.30319.1
** CPU speed: 2992 MHz (Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz), 2992 MHz (Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz)
** Total physical memory: 3547 MB
** Available physical memory: 2547 MB
** Total virtual memory: 2047 MB
** Available virtual memory: 1687 MB
** Free disk space on C: 219910 MB
** NI-DAQ version 9.3 and 9.5
** I\O Device USB-6501
Application: ProGo.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.AccessViolationException
Stack:
at <Module>._STL.basic_string<unsigned short,_STL::char_traits<unsigned short>,_STL::allocator<unsigned short> >.__dtor(_STL.basic_string<unsigned short,_STL::char_traits<unsigned
at NationalInstruments.DAQmx.Internal.DigitalSingleChannelWriterImpl.WriteSingleSampleSingleLine(Boolean, Boolean)
at NationalInstruments.DAQmx.DigitalSingleChannelWriter.WriteSingleSampleSingleLine(Boolean, Boolean)
at PhonakGroup.ProGo.Pic.PicTwo.SetProgrammingDeviceState(PhonakGroup.ProGo.Pic.PowerState, PhonakGroup.ProGo.Pic.ProgrammerDevice)
for the complete stack trace see attached.
