06-20-2012 09:11 AM
What is the purpose of the external switch?
A circuit like this can be used.
The operation can be understood with reference to the timing diagram below.
T1: Power to computer/USB-6009 turns On. Power on Reset signal goes High.
T2: Digital Port starts up as Input. Lines pulled High by internal resistors.
T3: Power on Reset signal goes Low.
T4: Program is running and configures Digital Port as Output. Lines are Low.
T5: Program sets DO1 High.
T6: Program sets DO0 High. This results in T6a: Q output of flip flop goes High. Which produces T6b: SSR turns on.
T7: Program sets DO0 and DO1 Low.
Lynn
06-28-2012 04:44 AM
Hi Lynn,
I have connected the D type Flip flop as per the diagram you have mentioned in the previous reply and it is working properly as what I needed.
but now I want to get 2 digtial output when it get trigger from 1 input, I have tried to add a another case structure to the existing program, but It give me a error saying case structure has not got a selector value, i have added a selector value, please can you advice me what is wrong in the program.
Program : Input Trigger --> Delay 1 --> Output 1
Delay 2 --> Output 2.
both delay should get the input from the same trigger at the same time and the delay operation should start at the same time.
I have attached the VI.
Veer
06-28-2012 08:21 AM
reason for that is your "T/F" statement case should only have 2 cases(one for TRUE and another for FALSE), not 3. What it looks like you are trying to do is to control the delays on the digital outputs independently?
06-28-2012 11:45 AM
Yes I want to control the delay of the digital output independently, Can you give me advise how to achieve this with the same Labview code or I need to make more changes to get two output. Can you give me some logic how to get it done.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
