03-27-2015 02:45 PM
Hi to all!
I am thinking on buying an USB-6001 module, but first I would like to emulate the adquisition system in my labview (2013).
Is there any manual about how to emulate this system and his variables? I would like to make some program first and tests inputs/outputs variables.
Thank you!
03-27-2015 04:07 PM
03-28-2015 12:32 PM - edited 03-28-2015 12:33 PM
thanx Dennis,
Maybe is because my total ignorance or because I need any other software from NI, but I can´t insert the device.
I only have the possibility to add/remove software, you can see the tree in the image included.
Can you give me some more explanations or an example please? Thank you
03-28-2015 01:23 PM
Right-click on "Devices and Interfaces". That is where you add the simulated devices. Though, it looks like you also need to install DAQmx.
03-29-2015 05:41 AM - edited 03-29-2015 05:44 AM
Thank you! It works finally!!!!
I have some other question please. How can I import this variables to the labview programe?
03-29-2015 06:07 AM
I recommend you go through the examples that are in LabVIEW (Help->Find Examples). Look for the DAQmx examples.
03-29-2015 08:18 AM
03-29-2015 09:06 AM
Yes! I am trying to work with it. Sure I make some new questions before buying the device.
Thank you very much
04-01-2015 01:52 AM
Hi again,
As you can see in the image included, I think I´m doing something wrong in the simulation.
First of all I have included the NI USB-6001 device, but an exclamation icon apeared --> ¿Is this correct?
Then I simulate with the "Test panel" an analog signal in the first channel "Dev1/ai0".
At least, I extract "DAQmx Global Channel" from this first signal (Dev1/ai0), and taken to a string visualizator.
I think It should be very simple to manage this variables... Would you mind to help me again?
Thank you.
04-03-2015 02:51 AM
Any help?
