Digital I/O
USB-6001 how to use?
Hi to all!
I am thinking on buying an USB-6001 module, but first I would like to emulate the adquisition system in my labview (2013).
Is there any manual about how to emulate this system and his variables? I would like to make some program first and tests inputs/outputs variables.
Thank you!
Message 1 of 19
(8,525 Views)
In MAX, under Devices and Interfaces, you can right click and add a simulated device. MAX gets installed with the DAQmx driver.
Message 2 of 19
(8,519 Views)
thanx Dennis,
Maybe is because my total ignorance or because I need any other software from NI, but I can´t insert the device.
I only have the possibility to add/remove software, you can see the tree in the image included.
Can you give me some more explanations or an example please? Thank you
Message 3 of 19
(8,496 Views)
Right-click on "Devices and Interfaces".  That is where you add the simulated devices.  Though, it looks like you also need to install DAQmx.
GCentral
Message 4 of 19
(8,488 Views)
Thank you! It works finally!!!!
I have some other question please. How can I import this variables to the labview programe?
Message 5 of 19
(8,476 Views)
I recommend you go through the examples that are in LabVIEW (Help->Find Examples).  Look for the DAQmx examples.
GCentral
Message 6 of 19
(8,471 Views)
Be sure to check the Help to see the limitations of what you can do with a simulated device.
Message 7 of 19
(8,460 Views)
Yes! I am trying to work with it. Sure I make some new questions before buying the device.
Thank you very much
Message 8 of 19
(8,457 Views)
Hi again,
As you can see in the image included, I think I´m doing something wrong in the simulation.
First of all I have included the NI USB-6001 device, but an exclamation icon apeared --> ¿Is this correct?
Then I simulate with the "Test panel" an analog signal in the first channel "Dev1/ai0".
At least, I extract "DAQmx Global Channel" from this first signal (Dev1/ai0), and taken to a string visualizator.
I think It should be very simple to manage this variables... Would you mind to help me again?
Thank you.
Message 9 of 19
(8,425 Views)
Any help?
Message 10 of 19
(8,381 Views)
