08-27-2012 10:05 PM - edited 08-27-2012 10:06 PM
Hi, I'm trying to pass a cluster in and out of a nested stacked sequence. I can wire the cluster into the sequences just fine, but I get tunnel errors trying to wire the cluster data out of the stacked sequences back to the main outside loop that contains the shift register. Are nested sequence structures allowed to pass clusters in and out of? Can someone please help with this.
Thanks so much,
Rob
08-28-2012 01:13 AM
You should avoid stacked sequences and use case structures instead ! A case structure in a while loop is a simple state machine which allows to set the execution order of the states very easily.
See here if you really want to use stacked sequences.
08-28-2012 07:00 AM
Sounds like you really should be posting this in the LabVIEW board. Can you post some code with the error?
