Digital I/O
Trying to cross digital I/O module over to NI unit.
Trying to cross from a Schleicher part# UBE24V1D to a National Instruments or other local compatible I/O Module
(3,670 Views)
I would have thought that your local NI field sales engineer would be the person to answer this kind of question.
As I have stated elsewhere, I'd recommend using solid state interface relays (SSR) between the I/O module and whatever you are controlling. This will give you more flexibility; e.g. you could use a module with I/O logic between 0 and +5 volts, and for each seperate channel select the appropriate SSR for the voltage that is coming in/going out.
(3,632 Views)
