Digital I/O
Trigger Camera with shaft encoder
Hi Guys,
I have an NI 9401 module and a cdaq 9174 chassis. I successfully connected my shaft encoder to the NI 9401 module and I can read the rpm and shaft position using a small labview program I wrote.
However, I need help outputing a 5 Volt TTL signal from the NI 9401 to trigger my camera. Any help would be greatly appreciated.
Thanks guys
(5,210 Views)
Hi Eluan,
The 9401 is configurable by nibble, so if you are using any of, say, lines 0-3 for input, you'll need to constrain your output to lines 4-7.  With that said, I would recommend taking a look at our DAQmx examples as there are several that perform basic output.  Here is one we have online:
DAQmx: Write Digital Pulse- Programmable High and Low Time - https://decibel.ni.com/content/docs/DOC-21943
Please note that this output will be software timed.  If you are looking for a hardware timed solution (e.g. "immediately" trigger a TTL output when a certain RPM is reached) then you'll need to switch to an FPGA-based solution.  You can also find additional examples in LabVIEW's Example Finder in Hardware Input/Output»DAQmx»Digital Output.
Chris Elliott
x36772
(5,207 Views)
I am using Labview 8.6 instead of the latest version. Can you copy and paste the vi so that I can see it?
(5,141 Views)
Hi Eluan,
I have saved the community example for LabVIEW 8.6. Let us know if you are able to open it now.
Bill E. | Applications Engineer | National Instruments
(5,129 Views)
