04-10-2007 04:20 AM
04-18-2007 09:13 AM
04-20-2007 08:01 AM
04-21-2007 11:26 AM
@DRau wrote:
Hi.
I'm developing an application using the PCI-6518 Digital I/O board under Visual C# 2003 with DAQmx V. 7.1.0.388. Everything is working fine so far, except one last open point:
If I terminate my program, the application hangs (mostly, from time to time it terminates properly) in a way, that I can't even kill it using the TaskManager. All I can do is to reboot the machine. Maybe someone can help me here. The problem occurs only when using asynchronous read access.
Some code snippets:
This is the method I use to register my callback functions that are called with the incoming data if a change was detected. It uses the helper method below to create a new Reader and starts immediately listening for incoming data.
public bool ActivateAsyncByteReadPort(int port, AsyncByteReadCallback callback)
if(IsInputChannel(port)){
DigitalSingleChannelReader daqReader=CreateAsyncReader(port);
m_ReadPorts[port]=daqReader;
m_ByteReadCallbacks[port]=callback;
daqReader.BeginReadSingleSamplePortByte(new AsyncCallback(OnDataReady),port);
return true;
return false;
private DigitalSingleChannelReader CreateAsyncReader(int port)
if(m_ByteReadCallbacks[port]==null)
string lineString=m_strDeviceId+"/port"+port;
Task digitalReadTask = new Task(null);
m_Tasks.Add(digitalReadTask);
digitalReadTask.DIChannels.CreateChannel(lineString,"",ChannelLineGrouping.OneChannelForAllLines);
digitalReadTask.Timing.ConfigureChangeDetection(lineString,
lineString,
SampleQuantityMode.HardwareTimedSinglePoint);
//disable timeout, wait forever for incoming data because the PLC may not be active yet
digitalReadTask.Stream.Timeout=-1;
DigitalSingleChannelReader daqReader = new DigitalSingleChannelReader(digitalReadTask.Stream);
return daqReader;
return (DigitalSingleChannelReader)(m_ReadPorts[port]);
This method is called every time a change was detected:
private void OnDataReady(IAsyncResult result)
int port = (int)(result.AsyncState);
byte data = ((DigitalSingleChannelReader)m_ReadPorts[port]).EndReadSingleSamplePortByte(result);
if(m_ByteReadCallbacks[port]!=null)
((AsyncByteReadCallback)(m_ByteReadCallbacks[port]))(data);
((DigitalSingleChannelReader)m_ReadPorts[port]).BeginReadSingleSamplePortByte(new AsyncCallback(OnDataReady), port);
As I already said, this works fine and does what it is supposed to do (it calls the callbacks when input changes). However, if I want to terminate the application, it seems that OnDataReady (or more likely the BeginReadSamplePort) doesn't stop. I tried the following (without success):
public bool Close(){
foreach(Task task in m_Tasks)
task.Control(TaskAction.Abort);
task.Dispose();
m_Device.Dispose();
return true;
So my question: What's the proper NI-way to terminate this application? How can I interrupt the BeginReadSingleSamplePortByte calls?
Thanks & yours,
Dominik
08-28-2013 03:03 PM
This problem is caused by a pending asynchronous read/write operation with an infinite timeout. You can reset he device programatically as a workaround to terminate the async operation:
NationalInstruments.DAQmx.DaqSystem.Local.LoadDevice("dev1").Reset();
where "dev1" is the name of your device. NI should really provide a method to terminate async operations, other than timeout.
