04-17-2013 01:53 AM
hi.. I am using DAQ 6216. I want to generate a TTL pulse with 1ms on time and 10ms off time
04-17-2013 06:31 AM
As mentionned here : LV menu >> Help >> Find Examples... >> Hardware Input and Output >> DAQmx >> Counter Output
Doesn't this help ?
04-18-2013 01:04 AM
Hi thanks for reply ..
i cudnt find any such example in the help
I had able to make a vi using DAQ assistant for the same. But want to make one without DAQ assistant function .. for more flexible output
04-18-2013 01:16 AM - edited 04-18-2013 01:17 AM
So just convert the VI from the DAQ Assistant and adapt it to your needs. The conversion is straightforward :
04-18-2013 01:39 AM
Hi..
Thanks for reply...
While using this vi , on DAQ output I am getting almost 6ms ON time and 15 ms OFF time (on Oscilloscope).
How to use a signal generator function to give input
04-18-2013 02:02 AM
What do you want to do exactly ? A function generator with variable frequency, duty cycle... ? Anything else ?
04-18-2013 02:16 AM
Hi
