Digital I/O
Sourcing a 15-pin D-SUB Twisted Pair cable to fit on a NI 9411 C Module
I have an NI 9411 that I'd like to connect to and I'm looking for a 15-pin D-SUB Twisted Pair cable.
I have spoken with NI sales and the best they can offer is the following, which is unfortunately not twisted pair:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/212301
They advised that I have a general look around on google/RS Components, which I've done. I've found quite a few straight-through
15-pin D-SUB cables but still can't seem to find one with twisted pairs.
Unfortunately, making my own cable isn't a viable option.
Has anyone ever used a cable like this and know where to buy one in the UK?
Thanks.
(4,612 Views)
Hi Split_Brain,
Unfortunately theres not much I can do to help with the 15-pin D-SUB Twisted Pair cable. I've had a quick search on Google and haven't been able to locate the correct cable for your needs.
DanC12
(4,561 Views)
Also looked for you at various sources in the UK and The Netherlands but came up empty.
In my case I would solder such cable myself but you don't want to do that.
Perhaps another solution is a flatcable with twisted pair. You can make such a cable without any special tools. If necessary you can use a bench-vice.
Kees
(4,558 Views)
