The 2803 will work, but you will need more than one since the max current through the die is 2.5A total. At 12V, your solenoids will draw 500mA each, that times 6 solenoids is 3A total. Also note that 500mA is the upper limit of the ouput drive, you may want to parallel two drivers together for each pump (just to be safe).
I could not find the current rating of the pump so once you know that figure, plan on spreading your loads between the 2803's accordingly.
-AK2DM
