I have an SCXI-1163R with a SCXI-1326 terminal block in a SCXI-1001 chassis with Labview 2014. I've set up a VI with a toggle button that switches (for example) ch12 to com3 using the niSwitch Connect Channels VI. I'm checking for continuity between ch12 and com3 with a multimeter and I'm getting some really weird problems.
If I switch ch12 to com3 by enabling my switch button, I read about 370kohm between ch12 and com3. If I disable the switch button, I read 6 ohms. This is backwards from what is expected, and even then it's never truly open. If I reboot the chassis, it will read open. If I check the switch status in NIMax, it will show connected when my button is disabled, and it will fluctuate between open and connected when my button is enabled.
I've tried multiple channels and they all do the same thing. I've attached the VI that I am using. I've searched everywhere and haven't found a solution, and the example VI is too old for my version. Thanks for any help.
