11-10-2014 02:35 PM
We have just upgraded to a newer PC running Windows 7 64-bit.
The old PC was Windows 2000.
The DAQ card NI PCI-6071E is detected in N(-MAX.
There are no errors in Device Manager.
NI-DAQmx 14.2 is installed.
The SCXI-1001 chassis is not detected in NI-MAX.
What else do I need to do?
11-11-2014 12:41 PM
You just need to add the SCXI chassis manually. Please refer to Step 11 from the link below.
http://www.ni.com/pdf/manuals/373236m.pdf
MCOTO
11-11-2014 02:02 PM
MCOTO
I was under the impression that NI-MAX should detect it automatically.
But I did follow the directions to add the SCXI chassis manually.
Yet there is a redX next to the icon and none of the modules are detected.
11-12-2014 02:42 PM
Just wanted to add that not only does the SCXI-1001 chassis have to be added manually so does its modules.
The Auto-Detect button did not work.
11-12-2014 03:32 PM
Were you able to properly add the modules to MAX and take some measurements? if not, here are some troubleshooting steps.
http://digital.ni.com/public.nsf/allkb/FA32B0EAEEA81D2586256D5200693BD2
MCOTO
11-13-2014 09:27 AM
I was able to add the modules with no errors.
Have not tried running the LabVIEW program yet.
