08-15-2012 07:31 AM
Hi there,
the task is to rebuild an already existing test system, because of redundancy.
The testsystem contains the PXI-6533 in a PXI-1000B. The problem is, that the PXI-6533 is not available any more.
So the option is to replace the PXI-6533 with the PCI-6534.
Do somebody have experiences in doing that.
Can be used the same connectors, are there any adjustments have to be done to the test software?
thanks for the help
Regards, McDuck82
08-15-2012 08:28 AM - last edited on 11-04-2014 01:58 PM by C-T
First of all, there is a <link no longer exists> available. I think these are on their way out too. NI is recommending upgrading to PXIe modules.
From what I can find in the spec and user manual, the only real difference between the PXI-6533 and PXI-6534 is that the 6534 has more memory. So it look like it should be a simple drop-in replacement.
08-15-2012 08:42 AM
That sounds great.
That's also my level of information.
Right, NI recommends the PXIe, but thats not compatible with the existing test software for sure.
So I think it will be the PXI-6534.
Greetz
11-04-2014 02:07 PM
Onboard memory is the main difference between the two boards. They use the same front panel connector, and the same PXI connector. Software is the same as well. We no longer sell the 6533 nor the 6534, so if you do not have one available with you, unfortunately you cannot purchase one. The transition to the PXIe boards is not trivial, so there may be some options with R series FPGA boards that may work better and keep the PXI form factor if that is a concern. Depending on the functionality of the board, you may be able to get away with a DAQ board's DIO lines as well. Hope you are able to arrive at a successful solution for your application.
11-04-2014 05:58 PM
