Digital I/O
Random segmentation fault when linking to nidaqmxbase under Linux (CentOS 7)
It seems that a simple C application that links to nidaqmxbase will randomly segfault.
Here is my setup:
C test app:
#include <stdio.h>
#include <stdlib.h>
int main (int argc, char **argv)
exit(0);
Now if I compile the above using 'gcc test.c' and then run a.out in a loop, it never segaults.  All good.
But if I compile the above using 'gcc ./test.c -lnidaqmxbase' then running the generated a.out in a loop will randomly segfault.
I found a topic in the forums that describes similar behavior (http://208.74.204.114/t5/Multifunction-DAQ/Segmentation-Fault-when-linking-with-NIDAQmx-Base-2-0-in-...) but the thread is pretty old so I figure this problem has probably been fixed by now.
Am I the only one having these segmentation fault issues?  Maybe someone is able to reproduce this?
Here is my setup:
CentOS Linux release 7.2.1511 (Core)
Linux Nrc-006933.ds.nrc.ca 3.10.0-327.22.2.el7.x86_64 #1 SMP Thu Jun 23 17:05:11 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
gcc (GCC) 4.8.5 20150623 (Red Hat 4.8.5-4)
Product: NI USB-6501
Driver installed from: http://ftp.ni.com/support/softlib/multifunction_daq/nidaqmxbase/15.0/linux/nidaqmxbase-15.0.0.iso
(Device firmware successfully updated after driver installation.)
Thanks!
  Andre
(3,927 Views)
And here is the info I get when I run the app in gdb:
(gdb) run
Starting program: /home/andre/work/nrc-rc/tictool/src/./a.out
Missing separate debuginfo for /usr/local/lib64/libnidaqmxbase.so.15
Try: yum --enablerepo='*debug*' install /usr/lib/debug/.build-id/6c/1972b3a293c1e198d3913da1e19f2da8c39959.debug
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Missing separate debuginfo for /usr/local/lib64/liblvrtdark.so.15.0
Try: yum --enablerepo='*debug*' install /usr/lib/debug/.build-id/74/fec2cc7ef569afda9ad86e1a2b9e745a8af622.debug
[New Thread 0x7fffef324700 (LWP 31312)]
[New Thread 0x7fffeeb23700 (LWP 31313)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffef324700 (LWP 31312)]
0x00007ffff6974ad1 in ?? () from /usr/local/lib64/liblvrtdark.so.15.0
Missing separate debuginfos, use: debuginfo-install glibc-2.17-106.el7_2.6.x86_64 labview-2015-rte-15.0.0-2.x86_64 libgcc-4.8.5-4.el7.x86_64 libstdc++-4.8.5-4.el7.x86_64
(3,918 Views)
Hello charbonneaua,
You can find in the known issues the following information:
Security-Enhanced Linux:
Red Hat Enterprise Linux WS 6 has Security-Enhanced Linux enabled by
default. While Security-Enhanced Linux is enabled, the utilities distributed
with NI-DAQmx Base 15.0.0 receive a segmentation fault signal. To
use the utilities distributed with NI-DAQmx Base 15.0.0, including the
"nidatalogger" and "FWUpdate" utilities, turn on the "allow_execheap" boolean.
Give it a try
(3,877 Views)
Thanks for the suggestion.
However, this does not seem to make any difference in my case.
For example, I set the selinux boolean :
# setsebool allow_execheap on
# getsebool allow_execheap
selinuxuser_execheap --> on
And then I run the code again and it will randomly segfault.  (On my last 10 invocation, it segfaulted 3 times...).
Sometimes, running the program I also get the following error message:
Error Message =Internal Warning 0x0037C03D : "MemoryManager.cpp", line 1425
LabVIEW version 15.0f1
For assistance in resolving this problem, please contact National Instruments Support.
Aborted (core dumped)
This seems like a memory allocation/deallocation bug and I'm not sure what I can do about this.  I would be curious if other people are able to reproduce this error or not.
(3,872 Views)
You may be running into the kernel stack size limit. By default, Red Hat/CentOS (at least with CentOS 6) uses a default of 4K. Can you try to recompile your kernel with a larger kernel stack size?
If you have more than 4 GB of RAM, you may also be running into addressing issues above the 4 GB boundary.
Please see instructions at https://forums.ni.com/t5/Linux-Users/How-to-install-DAQmx-8-0-2-and-LabVIEW-2011-under-RHEL-CentOS-6...
Tobias
Principal Software Engineer
Driver Software
(3,858 Views)
