07-13-2015 12:55 AM
Hi, I have developed a program for demodulation of RF data stream in FPGA 7999 interfaced with NI tranceiver 5791.Data gets demodulated and than stored to FIFO as required. After acquiring RF data stream it gets demodulated IN FPGA.Recovered data is than output from NI 5791 transceiver Digital IO port. I have question regarding data which is getting out from 5791 is in pulse like form.BUt I require data to be of continuous type rather than pulse form. My second query is that I also want to generate clock with the demodulated data.Right now I have mapped output enable pulse at output but my objective is to output a proper clock with akllmost 50% duty cycle with continuos demodulated data. VI is attached kindly look and guide accordingly.Thanks sample project is also attached
07-13-2015 01:01 AM
07-13-2015 01:14 AM
07-13-2015 01:21 AM
07-14-2015 12:48 AM
07-14-2015 12:59 AM
07-14-2015 01:01 AM
07-14-2015 01:02 AM
07-15-2015 10:36 AM
Hello sunnykillz,
What NI FlexRIO product are you using? I'm not showing the 7999 as a National Instruments FlexRIO device.
What PXIe chassis and PXIe controller are you using?
Your demodulated signal (recovered data) is a continuous Analog signal correct? You won't be able to output an Analog signal from a Digital I/O port. The Digital I/O port is only capable of 3.3 LVCMOS logic (which basically means a ~3.3 V High pulse or ~0 V Low pulse).
Are you wanting to transmit out (TX OUT) the time domain signal that you demodulated?
For outputting a clock, you can use the front panel terminal CLK OUT to export a clock signal. The NI-579x Configuration Design Library allows you to program your clock sources. Please see page 21 of the 5791R User Manual for information on available clock sources.
Please try to post your .png again!
07-16-2015 12:12 AM
