Digital I/O
PXI 7354
Hi
I am looking at the motion controller PXI-7354 in a PXIe-1062Q chassis with a PXIe-8108 Embedded Controller. After looking through the manuals and online sites for the PXI-7354 I have not been able to come to a clear conclusion of whether or not the motion controller could support operating an actuator as well as running a servo and/or stepper simultaneously. The manual states that the PXI-7354 has extra analog inputs running 16 bit, however I am unsure if those would suffice in what I am looking to do.
(3,302 Views)
Hi FRumd,
The thing to know is that you can't use a hardware trigger to trigger the Analog I/O and there are some rate issues that are addressed in this KnowledgeBase Article. Other than that you'll have access to the +/- 10V AIO so I'm thinking they could activate an actuator just fine depending on the requirements.
Also this question might get more relevant traffic on the motion discussion forum HERE.
Aaron F.
(3,281 Views)
