I'm re-designing an application that used PC-DIO-96 and PC-DIO-24 boards in a DOS PC to communication with a custom built hardware box. I believe the boards were used to control solid state relays in the box. I've found the original code (in BASIC) and values were written to port registers.
We are replacing the PC-DIO boards with PCIe-6509 cards in Windows 10 system and want to develop the new application in LabVIEW. Do I still need to read/write to registers or can I read/write to ports?
If I must use registers then does that mean I must use the MHDDK? If so, the objects are not listed as Win10 camptible http://www.ni.com/gate/gb/GB_EVALMHDDK/US
