Digital I/O
PCI-6602 creates error -88705 when executing Selftest in max
i get error -88705 (device not present) when runing the Selftest in NI-MAX.
in Windows device-manager it looks normal.
What can do do make it running again?
Thx
(5,616 Views)
you can try to do the following:
1. Try resetting the device in MAX.
2. If that doesn't work, reboot the PC.
3. If that doesn't work, shutdown the PC, move the card to another PCIe slot if possible, or take it out and put it back in making sure it is seated properly.
4. If that doesn't work, reinstall your DAQmx driver.
Have you tried to use this card in another PC?
Nina
(5,603 Views)
Hi, thanks for the help.
Meanwhile no.4 worked for me (re-install driver)
But i am not sure if perhaps also point 1 whould have been enough:
http://digital.ni.com/public.nsf/allkb/E4A2C6606CA13D0586257A0100505AFC
I found this too late (after the re-install)
(5,599 Views)
yes maybe that could have fixed the problem too.
Now everything works fine.
Have a great weekend!
Nina
(5,597 Views)
